Guest WLAN
shijomon scaria
Level 5
Level 5
Dear All,
I want to create one guest SSID in my WLC, which will provide only internet access. Can anyone please help me on this.
Thanks in advance,
Shijo.
maldehne
Please check the following links:
http://www.cisco.com/en/US/partner/tech/tk722/tk809/technologies_configuration_example09186a008067489f.shtml
Please Don't Forget to rate correct answers
Amjad Abdullah
Shijo:
You have experience with WLC? I mean can you create an SSID and map it to a vlan? or you need help with this as well?
maldehne link may not work with you. If it did not work here is a working link of the same page he is pointing to:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008067489f.shtml
You can create a VLAN in your wired network that is only reachable to the internet (you may use ACLs or firewall). Then create an SSID that is mapped to that VLAN.
Amjad
Rating useful replies is more useful than saying "Thank you"
