11-25-2015 03:53 AM - edited 07-05-2021 04:18 AM
AIR-CT5760 uses the new IOS 3.7
(ct5760-ipservicesk9.SPA.03.07.02.E.152-3.E2.bin)
Goal: user logs into GUI of AIR-CT5760 - user is authenticated and authorized by ACS - user has only privileges to access category "Monitor".
All descriptions of the previous operating system of older WLC don't help!
Don't post descriptions of the old WLC operating system
Solved! Go to Solution.
11-25-2015 11:28 AM
Hi Marcus,
Hope this is you looking for
Rasika
*** Pls rate all useful responses ***
11-25-2015 11:28 AM
Hi Marcus,
Rasika
11-30-2015 03:59 AM
Hi Rasika,
thank you for the provided link.
Hint:
With Software Version ct5760-ipservicesk9.SPA.03.07.02.E.152-3.E2 it doesn't work as described.
But with Version 3.06.03 it works.
11-30-2015 10:25 AM
Thanks for that hint. I would assume it may be a code specific issue in 3.7.2
Rasika
