HA Configuration dcloud 9800
jasonjefrey1
Hi everyone
What is the recommended IP Add to use when configuring HA? The wireless management IP range or the controller management IP range the one we use to login via the web?
jason
18 Replies 18
only the primary controller, once HA is formed HA controller IP is over written by primary controller IP.
I would also recommend that you open a separate discussion for each new topic, its easier for the community member to track and help and its convenience for other community members when they are searching community topics.
-hope this helps-
@ammahend
Thank you! The HA is working. I just need to sort out the self-signed certificate. I'll try rebooting the APs and see how it goes. Thank you for your advice. It's much appreciated.
Jason
     >...should we calculate it as one controller or two
             One controller ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
