HA SSO and web-auth
omer shtivi
Hello everyone!
We recently bought a new WLC (5508) to be in HA with our current WLC.
We added the WLC to the HA and everything seemed to work fine.
We did a failover and our web-portal (captive) didn't worked.
Looking at the new WLC it's looks like the HA didn't received the web-auth files (we got custom web portal).
Does someone knows how to sync it?
Thanks!
Omer Shtivi
Actually it didn't helped.
You need to upload the web-auth files before the HA setup, the HA doesn't sync the files.
If you forgot issue a switchover and then upload the files into the WLC.
I think it depends on the code version. The later code has a peer upload feature and I think I did see the WebAuth upload there. The certificate if using one, you have to upload to each.
-Scott
-Scott
Hi Scott,
The peer upload is to upload a file from the WLC, not download to the WLC (tricky naming).
We arwe using version 8.0.120.
