Having issues with joining AC Wave 2 APS to WLC
nmack25
Hello!
I bought a WLC 5508 with 75 AP licenses, but the AC Wave 2 APs are not adopting. WLC has been updated to: "AIR-CT5500-K9-8-5-182-0.aes". Anyone have any ideas on how to solve this?
INFO ON NETWORK:
Wanted to switch from Mobility Express to WLC. All APs have been reset using mode button on back.
3702: Joined successfully
2702:Joined successfully
1810w error:
2802 error:
 3802 error:
WLC screenshots:
Network Summary:
Let me know what you think. Yes the UDM-SE is not a "pro" device. Just using it since no licensing and I use protect/access.
More info:
I set up the WLC using the initial CLI configuration.
I am using port 1 on the WLC
Noah
7 Replies 7
nmack25
Now having this issue with my 3702s
marce1000
 - You seem to have APs with expired certificate(s) ; according to https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html   try :
                         ap cert-expiry-ignore mic enable
                         ap cert-expiry-ignore ssc enable
 M.
Getting this error.
% Invalid input detected at '^' marker.
Got the aps showing up, but none register
 - My bad ; the correct commands are :
                         config  ap cert-expiry-ignore mic enable
                         config  ap cert-expiry-ignore ssc enable
 M.
Still getting the same issue....weird
 As per https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html upgrade to :
                       https://software.cisco.com/download/specialrelease/2702eede2b47a5c3bb40795bbe836af6
 and try again ,
 M.
