heat map
Network Pro
Level 7
Level 7
Hi all,
is there any program to produce heat maps similar to what Cisco WCS does? WCS is expensive...i need a free version or a demo version will do..i have the maps. just need to produce heat waves so that  i know where to locate the Access Points for coverage
Network Pro
Level 7
Level 7
any thoughts on the above ?
