Heatmap
Tazio4436
Level 5
Level 5
I am using using Cisco WLC 2500 with some AP type AIR-AP1852E-A-k9.
Is there anyway i can get a heatmap?
Tazio
2 Accepted Solutions
balaji.bandi
Not sure you have Prime infra for heatmap ? or you looking any other tools ?
BB
Arshad Safrulla
It depends on what you want, are you looking for an predictive heatmap or an post deployment heatmap?
Market leader for heatmaps and WLAN planning is Ekahu. If you need to take an post deployment coverage verification then you might need an Ekahu side kick as well. Ekahu is expensive and it is worth the value most of the times. But looks like they started taking classes from Cisco on the licensing.
Other options are
1. Airmagnet
2. Tamograph
3. Acrylic
Select what works for you best, I suggested Ekahu just because our organization uses them.
Cisco Prime is not a WLAN planning tool nor post deployment verification tool, it just provides you with an estimated coverage based on the parameters it learns through your infrastructure.
5 Replies 5
balaji.bandi
BB
I don't have Prime Infrastructure. I can look into any other tools or solutions .
Tazio
try :
https://www.nectus5.com/cisco-wireless-heat-maps/
BB
Hello All,
I have tabled all the suggestions to my management but did not approve anything due to budget constraints.
Thanks ok.
I learnt new things by reading the documentations of all the proposed solutions.
Thanks again.
Tazio
Arshad Safrulla
Other options are
1. Airmagnet
2. Tamograph
3. Acrylic
