Help 1812w router
Kananavicius
Hello I have cisco router 1812/k9 witch don't have wireless capability
router CISCO1812W-AG-E/K9 does.
My router have mini PCI slot in witch I can plug Wireless mini PCI card
sow maybe some body know witch Wireless module is my
If you have router CISCO1812W-AG-E/K9 pleas open end have look what type of wireless is in that router, copy the numbers an if you can mace the photo wireless card and main board thank you.
5 Replies 5
Rob Huffman
Hi Justas,
I don't think this will work :( Have a look at the following;
Q. Can nonwireless routers be upgraded to support wireless capabilities?
A. No. The Cisco 1800 Fixed-Configuration routers are not field upgradeable to include wireless support. Customers or partners must specify at the time of ordering whether a wireless or non-wireless model is desired. After it is ordered, a nonwireless router cannot be upgraded to support wireless operation in the field.
From this doc;
http://www.cisco.com/en/US/products/ps5853/products_qanda_item0900aecd8028a95b.shtml
Hope this helps!
Rob
Please remember to rate helpful posts.....
Yes I have readied that but I all so thinking
What it will work, because there is Mini Pci slot to plug the wireless module
You see when I have boded this router from USA from Web-site I live in UK
And they laying to me so that router has wireless capability.
When I get my router no wireless was inside and no return label.
The web-site http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1964651&CatId=373
But in the web-site there is told that router has wireless
Rob Huffman
Hi Justas,
If you got the wrong part from this company, you should send it back and get the proper one.I had a look at the link that you sent and there is a return policy. Have a look;
RETURN PROCEDURE
http://www.tigerdirect.com/sectors/help/return.asp
Perhaps you could also give them a call @
International Callers 305.415.2201
Hope this helps!
Rob
Yes I have readied that policy
So when I had ring for them an speak with them
They told returns possible but it will cost to me additional
130 ₤ to send to them this router and only 921 $ they will send to my
Account plus wire transfer as well will be from my pocket so in
Total I will loose 135 ₤
Justas
Thank you for help
Hi Justas,
I'm sorry to hear that this process is so expensive :( Did they admit that they sent you the incorrect 1812? If so,I thought that they would waive any additional fees.Check your original order and see who made the mistake, if it was them, hold their feet to the fire.
Good luck!
Rob
