help aironet 1240 ag
luisgomezgomez
hello
I have to create a ssid and configure security with encryption and password wap ascii "log2011mfe"
I set it up via telnet command with the deputy and all is well finished with crltZ and all is well, but when the web server aironet, tells me that the wireless is down, that there is no ssid configured
1240AG> enable
1240AG# configure terminal
1240AG (config)# interface dot11radio 0
1240AG (config-if)# encryption vlan 40 mode ciphers tkip
1240AG (config-if)# ssid Guest
1240AG (config-if-ssid)# vlan 40
1240AG (config-if-ssid)# authentication open
1240AG (config-if-ssid)# authentication key-management wpa
1240AG (config-if-ssid)# wpa-psk ascii log2011mfe
Product/Model Number: AIR-AP1242AG-E-K9
  System Software Filename: c1240-k9w7-tar.123-8.JA2
  System Software Version: 12.3(8)JA2
  Bootloader Version: 12.3(7)JA1
  System Uptime: 55 minutes
6 Replies 6
Stephen Rodriguez
After you do the config in the cli you need to do a wr mem.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
hello
thanks for your quick response
but do not understand I'm a newbie
I have to reboot?
I do not understand this: need to do a wr mem
What Steve meant was this:
AP# wr
Hi Luis and welcome to CSC.
What Steve and Leo are mentoning about the "wr mem" is to SAVE your config after you have configured your access point. Have you done that ?
Amjad Abdullah
Luis:
My colleagues metnioned you should save the config but I think it should work without saveing the config. if config not saved then you will lose hte configuraiton after restart. However, after configuation and before save the configuraiton should be applied.
What do you think guys?
Make sure that your radio interface is not shutdown.
(show ip int brief) command will show you what interfaces are up and what are down.
but before that, have you configured the SSID?
this is configured before configuring the interface:
(dot11 ssid Guest).
It was long time since I dealt with autonomous. But I am sure that dot11 SSIDs are configured separately (not inside the interface) with their authentication mechanism. Then After doing that you add the SSID under the interface (ssid Guest).
Try it this way.
Good luck.
Amjad
Rating useful replies is more useful than saying "Thank you"
Amjad Abdullah
One more thing came to my mind:
you need to enable broadcast for the SSID with the command "guest-mode".
are you doing this in your configuration?
