help !!!ap350 Radio Forwarding State: Blocking
victorchen
What happen to my ap350 ? I find that the Radio still up, but can't pass any traffic. the version of my ap350 is 12.04.
kmarrero
Level 4
Level 4
Check your configuration and make sure that packet forwarding is enabled on the Ethernet Advanced Page. Also make sure you have clients associated to the AP. If there are no clients associated, then the AP will automatically go into Blocking State. The following is an excerpt from this URL: http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch3.htm#wp1025620
"The forwarding state displays the port's current forwarding state. The state for normal operation is Forwarding. Four other settings are possible:
•Unknown—The state cannot be determined.
•Disabled—Forwarding capabilities are disabled.
•Blocking—The port is blocking transmission. Blocking is always displayed when there are no clients associated to the access point.
•Broken—This state reports an Ethernet port failure "
