Help Configuring Cisco C887VA-W-E-K Wireless
rafik.harrar
Community Member
im having trouble to configure the wireless on the Cisco C887VA-W-E-K router.
I managed to get the DSL working using cable, but cant seem to connect to the router when i use Wireless. I can see the SSID and when i double click on it i get the Network Key promo. I input the network key, the router seems to try and connect me but then it fails, its as if the router cannot give me an IP address even though i have DHCP configured on the router. Maybe the AP and The router arent linked up?
I have configured many wireless devices in the past, but this new model is different, it seems Cisco have changed their router infrastructure and seperated the router from the AP.
From the router i can ping the AP IP address and i have the latest IOS - C800-Universal-mz.SPA.151-4.M4
Any help would be appreciated - thanks in advance.
Here is a copy of the config
ROUTER CONFIG:
Building configuration...
Current configuration : 3681 bytes
! Last configuration change at 14:11:43 UTC Mon Jun 18 2012
version 15.1
hostname Test-DSL
boot-start-marker
boot-end-marker
enable secret test
no aaa new-model
ip source-route
ip cef
ip dhcp excluded-address 192.168.0.1 192.168.0.3
ip dhcp excluded-address 192.168.0.201 192.168.0.254
ip dhcp pool ccp-pool1
network 192.168.0.0 255.255.255.0
domain-name test
dns-server 8.8.8.8
default-router 192.168.0.1
ip name-server 8.8.8.8
no ipv6 cef
license udi pid C887VA-W-E-K9 sn FCZ1620C0VP
username test privilege 15 password 0 tes
controller VDSL 0
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Embedded Service module interface to manage the embedded AP
interface Vlan1
ip address 192.168.0.1 255.255.255.0
interface Dialer1
description Primary Interface - DSL
ip address negotiated
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname username@tes.net
ppp chap password 0 test
ppp ipcp dns request
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
AP CONFIG:
Current configuration : 1847 bytes
version 12.4
no service pad
service password-encryption
hostname Test-AP
logging rate-limit console 9
enable secret 5 $1$6.kH$9KA54FGNt5OM7r/BeEopB0
no aaa new-model
dot11 syslog
dot11 ssid Test
   authentication open
   mbssid guest-mode
dot11 ssid Test-Aramark
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 032F5205011C2C494F0D
username build privilege 15 password 7 06041A28404A
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 30
ssid Test
ssid Test-Aramark
antenna gain 0
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0
basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 basic-m0. basic-m1. basic
-m2. basic-m3. basic-m4. basic-m5. basic-m6. basic-m7. basic-m8. basic-m9. basic
-m10. basic-m11. basic-m12. basic-m13. basic-m14. basic-m15.
station-role root bridge
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecti
ng AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.0.3 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community wrtnwsn RW
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Amjad Abdullah
Hi Rafik,
I think this will help you:
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/wlan.html#wpxref58512
Amjad
Rating useful replies is more useful than saying "Thank you"
Amjad Abdullah
Hi Rafik,
Amjad
Hi Amjad,
Thanks for your reply. I did look at this link before i posted on here.
I tried to follow the instructions from cisco as best i can but it still doesnt work.What am i missing from my config?
I started from scratch again and this time its working. The only noticeable difference is the following on the router config
interface wlan-ap0
ip unnumbered Vlan1
i believe the "IP unnumbered" Vlan1 command is what link the router with the AP.
On the AP, there was a few things that changed, here is a copy:
Current configuration : 1439 bytes
version 12.4
no service pad
hostname Test-AP
no aaa new-model
dot11 syslog
dot11 ssid Test-AP
   authentication open
   guest-mode
   wpa-psk ascii 0 Test
bridge irb
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid Test-AP
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
description  the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.0.2 255.255.255.0
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
end
