Help for updating the ws-svc-wlan-k9 software
Angel Popov
Hi, I bought one ws-svc-wlan-k9 module. But the seller did not clear the settings. and I don't have access to CLI.
I found a description of how to clean it, but I can't find anywhere to download these images.
c6svc-wlan-k9w7.passwd.recovery.1.1.1.bin or c6svc-wlan-k9w7.1.4.1.bin
You need a support contract to download the images from Cisco.com
You might be able to clear the config and the password doing this:
You have to reset the WiSM to the default configuration in order to reset the password on the WiSM. Use the same procedure as standalone controllers. You have to have access through the console port, reboot the controller, and break into the bootloader as the system boots up.
Useful info on how to do this here: http://netterrene.blogspot.com/2014/08/cisco-wlc-password-recovery.html
*****Help out other by using the rating system and marking answered questions as "Answered"*****
jamesbos96602
you know not allways true, 7 months ago cisco staff agree with contack with me  why, cisco 6500 swich wism2 card certific error, no one could recode the swich so cisco not fix it so i told cisco i crash it get all logs u need and i recode it in return i want all updates comes of this, u see i have add, my mind sees patterns in how software works what takes people years learn i learn in weeks. i help microsoft from dos up to 2016  then well lets say i found they takeing files off my pc so i had stop them
so it ended the help why , in a 6000 program that reqired 3 servers to run it after full install all updated it i crash it and taken down all 3 severs,  3ed time micosoft wanted build each server so they did 14 mins latter one acktion crash all servers, i know why it was going on but they told me could not be fix in fack i fix it  ,  out 200 cases microsoft close 0 i closed all 200 in order for me find probem i need hardware and software, busness ack given me hardware some off ebay, to find out if possable get up and running others, needed software fixes only microsoft alow me access to, i have hp tipping point firewall , i have server that run 10 servers at once in vmware,  and cisco got there wism2 card fix and i got 5 updates , wich fix all the probems,   what u all seam not understand dose not take schooling fix these devices, just a person who find pattern in how they crashing
i have a 5020 if i not mistaken odd swich if u run debug commands in certen order u pull all information off your servers,all information, lic information dates installed who uninstalled it, dates was uninstalled accounts used in fack i found cisco hidden accounts, part call home , i beleave,  i do know cisco has uses above admin in fack my swich was going back to cisco radius servers  and i not remove it cisco remove it with out permision wich meens they got around the securty,  well that was back then untill i trace all cisco remote servers, i know who made rasomware,  i help ibm install warrenty hardware with out being train by them they all new me and they all new i could do it when few others could, my spelling is do add, but given me insight in to servers others lack not say i better not at all i see the probems, you all cant, i tell u ever probem in server 2022 as base on windows 7 core so all software shares same probems and gus what i got proof if u like see it i prove who hacking all compuers and how they getting in , but there cost to this as to get this taken 3 years my life,   so your people will give up updates if so will befit them but for me must also binfit me as well , and there nothing u have not made that i cant find probems in ,  nothing as no software perfick now might take me time figger out i got ibm power 6 i lost on it so dag on diffrent that i dont know what i done wrong,  so even for me i need people like u solve probems,  but as u will del this  just know i was only person who could solve 12 of your hardware probems,  but in most cases busnss sent me hardware figger out as i had lern code it , find how crash it , and run all debug commands at same time , u see my mind can see the endless amouts of lines made but only looking for one thing that is out place, and most time that the probem,   wism u right if u use consol cable u break befor boot one commands is reset card, will do factory reset,  once done it be reconfig as one needs , and config these are not like any your documents, in fack if i use your documents i cant get working , wism has probem with the 1000gh poe card  as this card wont athencate as wism requires , now i not sure why this was never fix, but there is work around as in all things,  so everything is not contrack or end, in fack u provide cisco a valid carsh report they must replace the software even out contrack under usa law alows people fix hardware and requres the busness to provide needed items to do it, should look in to the laws, also cisco has policy as well that will permit software updates if falls in it and as i only used it few times i forget what called , in fack cisco is oblgated to provide fix for above probem, and u know what i dont think cisco want this go cort as if u lost guss what that right
