1830 Mobility Express 5Ghz Problem
saba53
Hello, I have Cisco Mobility Express 1830 AIR-AP1832I-E-K9, with additional 9 same model APs and one little different AIR-AP1832I-I-K9.
We are having issue about 5Ghz network, on AIR-AP1832I-E-K9 model access points, clients only connect to 2.4Ghz network, but on AIR-AP1832I-I-K9 we can connect to 5Ghz as well. They are using same WLAN with config to use 2.4Ghz as well as 5Ghz.
software version is 8.8.111.0
If anyone has suggestion about solution, please respond. Thanks
5 Replies 5
balaji.bandi
i would verify the settings and also other suggestion as below thread :
https://community.cisco.com/t5/wireless/not-work-5ghz-on-ap2802i-mobility-express/m-p/4755013
BB
Rich R
-E (Europe) and -I (Algeria/Bahrain/Belarus/Egypt/Israel/Kuwait/Morocco/Tunisia/Uzbekistan) APs are different regulatory domains.
https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
What country are you trying to use these APs in?
What country do you have ME configured for?
You should be aware that in most countries it is illegal to use APs from the incorrect regulatory domain.
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
Mobility Express is configured to country IL - Israel.
It is legal to use different country codes in my area.
My question is, if i change from Israel to Germany for example, will APs E versions work on 5GHz? (or can you tell me which country code has less restriction)
You should only use access points that are manufactured for that country. Not doing this can get you in legal troubles. You can’t change the ap country code, you can only update the controller configuration to tell it, what ap’s will I be supporting. That is opposite of what you are trying to do.
-Scott
The moral of the story is that you must buy the correct model of AP for your country!
