help implement vtp
davidlagat
Community Member
I am required to implement VPN on an existing net., for an organisation. The org., has 2 remote sites. One of the site has a wireless network with 3 access points done with alvarion. The other site has a connection to the internet. The 2 sites are connected thro wireless. Please, advice on the use, placement and configuration of firewall and concentrator.
1. Are cisco routers compatible with Alvarion Products.
2. Where do I do my compression?
3. How best can I implement this network.
a-vazquez
Level 11
Level 11
Yes, you can set up a two routers and VPN between the bridges. The bridge cannot terminate or begin the VPN tunnel. You have to use some other device to form the VPN tunnel. And I dont think that Cisco Routers are compatible with Alvarion products.
