02-24-2003 01:01 AM - edited 07-04-2021 08:31 AM
I'm new in wireless, and my boss force me create an wireless solution for a big meeting hall.
It's is a big meetting hall with 40m long, 20m width, the requirement is 50-60 laplop can access to data center through wireless.
I'm thinking of two 350, is it OK ? Do I need an 12000 ?
Please hepl me on this
Thank you in advance.
02-24-2003 07:02 PM
Hi ,
If you want to go for 802.11b based wireless than 2 AP are enough but for
better throughput per user go for THREE AP 350 .
Ap350 is only for 802.11b standard ( 11meg - shared )
Ap1200 can do 802.11a ( 54 meg shared ) and 802.11b
In 802.11a standard there are 3 non overlapping channels like 1 , 6 and 11 .
So you can put all 3 AP in same are . This way you can get 11X3 =33 meg and
you can do load balance across 3 AP .
Rule of thumb is 25 users per AP .
Nilesh
02-25-2003 07:24 PM
Hi Nilesh,
Thank you very much for your response. It will help me a lot.
BTW, could you recommend some helpful online material for Cisco wireless solution and technical aspect.
Hoang Duc Phuong
