Help needed
ivantebusweke1
Community Member
                   Hey i have aan air cap 1552 e AP that i want to serve clients of laptops n PDAs but then the access point comes in bridge mode,
Can i use it or it can only connect to other wireless access points?
Scott Fella
You need a WLC in order to use that model AP. With 7.3, you can set that to FlexConnect and use it as an AP, but follow the FlexConnect guide to understand how FlexConnect works.
http://www.cisco.com/en/US/products/ps11635/products_tech_note09186a0080b7f141.shtml
-Scott
