Help on 877w
aa.raaz
Community Member
I would like to have a bit of help here on 877w adsl wireless routers.
All is working fine from wlan perspective.
What I plan to do is as follows
Plan - I want network users and guest user access on 877w. Security is very crucial, as don't want guest users to access lan but only internet.
1. Create 2 vlans
2. Create 2 ssids
3. Create two subnets 1st for users, 2nd for guests.
4. Assign 1st Vlan / ssid / subnet to network users.
Assign 2nd Vlan / ssid / subnet to guests.
5. Network user wlan auth/encryption will be wpa2 (tkip / aes).
6. Guest user wlan auth/encryption will be wep (open authentication).
7. Block all layer 3 access or traffic from guest subnet.
I want to configure this through command line or SDM. But I keep getting confused and lost. Kindly help.
Thankyou all
thomas.chen
Level 11
Level 11
This part of the software configuration guide presents a variety of possible Ethernet- and Digital Subscriber Line (DSL)-based network configurations using the Cisco 850 and Cisco 870 series access routers.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d273.html
