help on wireless broadband
mkose
Community Member
I have a customer outside the USA and want to
set up a wireless internet service within 20-30
miles radius of a city.
What is the best way to do this?
thanks
murat
mkose@nurtel.com
5 Replies 5
devinator1
Community Member
Cisco's WT2750 solution.
datalink
Community Member
Hi Murat,
If you haven't found enough info let me know.
Anthony
Sir,
I found one of you discussions and I could not find the solution. I have a similar challenge of setting up wireless internet services within 20-30 miles radius of a city and I hope that the answer to that same challenge will also benefit me. Can you please explain the solution that you gave Mr Murat's challenge at that time to me?
Adebowale Nureni
Operations Manager
Farnet Systems
abrusilovsky
Community Member
Proprietary solutions like LMDS and MMDS are doing just that. Actually, MMDS is more appropriate in your case. (LMDS - Local Multipoint Distribution Service,
MMDS - Multichannel Multipoint Distribution Service)
MMDS is being used by Sprint Broadband to provide Wireless broadband in some areas, however, they stopped accepting new customers. Official explanation was that MMDS is not economical solution.
IEEE 802.16 is an emetging standard poised to replace MMDS/LMDS and promissing up to 155 Mbps in the 2-10 GHx lisenced and 11-63 unlicences spectrum. 802.16 is for building wireless metropolitan area networks as an economical method of high-speed (2 - 155Mbps ) "last-mile" connection to public networks.
802.16 was ratified last December. It may take another half a year to a year to see any GA 802.16 equipment on the market.
Alec
blue.modal
Level 6
Level 6
WT2750 was killed off long ago.
LMDS and MMDS are licensed and may not be available in all countries.
U-NII and 802.16 are the right place to look for higher speeds (no Cisco products), but you can do what you are asking with 802.11b if correctly engineered.
If you want to serve mobile clients, you will need towers every kilometer.
