Help plz.
Will102771
Community Member
I need to set a password to my wireless router. How would i do this?
Mark Elsen
 - What is the model (name)  of that device ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Martin L
you can google for documentation specific for your model / brand. also, you can reset a device (usually small hole on back) and then get into with default admin name and password (those also should be listed in documentation.)
Regards, ML
**Please Rate All Helpful Responses **
