Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Check both access points configurations to make sure that the SSID did not change. If you were using any type of encryption make sure those configurations did not change either.
Learn, share, save
