HELP WIRELESS MESH
pgonzalez
Frequent Visitor
Frequent Visitor
Hi Guys
I need someone can help me please, my problem is this:
We have a wireless mesh network with 2 WLC and 24 LAP1510AG (4 RAPs), which are registered to the WLC 1 when tested HA, i turn off the WLC 1 to operate the WLC 2, there were only 12 of the 24 APs are registred with WLC 2, when we made the turn of the WLC 1 have been recorded the same 12.
the debug LWAPP events enable command only shows activity of registered APs.
We have set to factory defaults all APs register (12) but nothing.
Any help be welcome
Thank you very much
HG
ehlers.kevin
Did you add the mesh mac addresses to the mac filtering database? That's usually the problem when mesh aps don't join our controllers.
if I added all the APs to the MAC-Filtering
The APs have been properly recorded with the WLC1, the problem arises when shut down WLC1 then the APs not registered with WLC2 only do 12.
Have you done
debug pm pki enable
on the controllers? You should see those messages even if you don't see the capwap messages.
