HIGH_POWER_CLASSIC_NOT_CONFIGURED AIR-WLC2106-K9
simonwynn
I have a WLC  2016 and a LAP1131AG plugged in to one of the POE ports. On firmware 7.0.116 I have no problems powering the AP.
On  6.0.222 I get an error:
and the usual radios off.
How do I get the 2106 to power this correctly, or have the thresholds of low power perhaps changed?
Simon
Leo Laohoo
Go to "All APs", click on the AP of your choice, go to the "Advanced" tab and on the right-hand section under PoE.
Do I select "Pre-stadard state"? Funny how this worked on 7.x...
Simon
Yes.  Select "Pre-Standard".  This may reboot the AP and you'll know it works because radios will go up.
