hot standby problems
fsoffia
Level 3
Level 3
hallo,
I have 2 Air-AP1242-AG-E-K9 access point.
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.3(8)JA2, RELEASE SOFTWARE (fc1.
I'm configuring one of them to be an HOT STANDBY of the other.
The HOTSTANDBY ap associates to the MAIN ap but become ACTIVE after the first timeout, but the MAIN ap works fine !!
There are little commands but it does not work !!
can you help me ?
best regards
francesco
Not applicable
check whether client associates with standby unit or not?. are you able to ping both AP's?
