hotspot using only AP's
is it possible to build a hotspot using only access points? can an ap or two be used to act as radius servers? is there a cisco guide for this?
bwilmoth
Level 10
Level 10
You can refer to this guide for hotspot configuration wth access point:You need to apply the latest patch to make the hotspot work with access point
http://www.cisco.com/univercd/cc/td/doc/product/aggr/bbsm/bbsmhs10/relnotes/hs10sp1.htm#57552
