How can I copy a PSK from one WLAN Controller to another
tdennehy
Level 2
Level 2
I'm trying to replace a WLAN controller with a new one.  One WLAN is configured with WPA-PSK.  Nobody seems to know the key that was used.
Anyone know if there is a way to extract the encrypted key out of a controller and put it into the new WLAN Controller?
Thanks in advance.
Na... The WLAN move was pretty easy ..
I would open a ticket with vocera about this issue and tell them about the hash .. They should be able to do it ..
5 Replies 5
George Stefanick
No can do ...
https://supportforums.cisco.com/discussion/11364566/view-psks-wlans-wlc
However, if any users are on a MAC Book and has iCloud enabled you can see the key under the "keys". If you have a windows 7 box and uses the native supplicant you can expose the key on the supplicant ..
This just happens to be a Vocera badge WLAN.  No clients other than badges...
If vocera can get to the hash in the vocera server you might be able to get the key. We had this problem. We ended up setting up a new WLAN and doing a push to the badge and moved them to the new WLAN with a new key ..
Got that hash.
That sounds extremely painful - setting up new WLAN, etc.
