How configure AIR-1142N AP as a Repeater?
firestormnet
Hi all.
Is it possible to do that?
I want to try to configure some APs as Repeaters, as I can't get a cat5 to some locations.
I've tried 1130 and 1140 CLI commands, but they didn't work. Couldn't find anything in WLC 2112 GUI configuration window as well.
For AP mode, there is no option as Repeater.
I'll be highly appretiated if someone will show me the right direction.
Regards.
2 Accepted Solutions
Surendra BG
Repeater is not supported under WLC infrastructure desing.. REPEATER is a Autonomous terminology!!
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
john smith
i am totally agreed with Surendra that
Repeater is ios based access points terminalogy
please let us know are you using WLC in your wirelss Lan infrastruture ?
if yes than you can't achieve this OR
if no you can configure one access point
as a Root and the rests as repeater
only in ios based (without Controller) access points.
please let me know if this answered your question
FARRAKH
Surendra BG
Surendra
Surendra BG
john smith
FARRAKH
