AP will not join 4402 Controller
Hello all,
I have a 4402 Controller and two APs that will not join.  Any sugguestions would be great.
Matt Michaluk
2 Accepted Solutions
This AP has joined the WLC hornell-wlc2
Surendra
Surendra BG
Force the AP from the secondary WLC to the first by making the HA settings,,
Surendra
Surendra BG
8 Replies 8
Surendra BG
Whats the AP model?? whats the WLC software version?? what does the logs say?? Without this its difficult to answer!!
Surendra
Surendra BG
AP 1250
Software Version:6.0.182.0
*Aug 08 16:57:46.235: c4:7d:4f:36:9d:20 Discovery Response sent to 10.1.50.168:62475
*Aug 08 16:57:46.235: c4:7d:4f:36:9d:20 Discovery Request from 10.1.50.168:62475
*Aug 08 16:57:46.236: c4:7d:4f:36:9d:20 Discovery Response sent to 10.1.50.168:62475
*Aug 08 16:57:46.236: c4:7d:4f:36:9d:20 Received LWAPP DISCOVERY REQUEST to 00:24:c4:13:a3:e0 on port '1'
*Aug 08 16:57:46.236: c4:7d:4f:36:9d:20 Discarding discovery request in LWAPP from AP supporting CAPWAP
I need the complete logs.. Reboot the AP and then wait till the AP rebots on its own.. and paste the logs
Surendra
Surendra BG
Username:
IOS Bootloader - Starting system.
Xmodem file system is available.
flashfs[0]: 12 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31868928
flashfs[0]: Bytes used: 8128512
flashfs[0]: Bytes available: 23740416
flashfs[0]: flashfs fsck took 16 seconds.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: c4:7d:4f:39:3f:fe
Loading "flash:/c1250-k9w8-mx.124-21a.JA/c1250-k9w8-mx.124-21a.JA"...############################################################################################################################################################################################
File "flash:/c1250-k9w8-mx.124-21a.JA/c1250-k9w8-mx.124-21a.JA" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1250 Software (C1250-K9W8-M), Version 12.4(21a)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 08-Jun-09 16:49 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 12 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31868928
flashfs[1]: Bytes used: 8128512
flashfs[1]: Bytes available: 23740416
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio0  present A600 8000 A8020000 0 A8030000 30
Radio1  present A600 8000 B8020000 0 B8030000 13
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP1252AG-A-K9    (PowerPC 8349) processor (revision C0) with 49142K/16384K bytes of memory.
Processor board ID FTX1347912G
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power-on
LWAPP image version 6.0.182.0
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: C4:7D:4F:39:3F:FE
Part Number                          : 73-10425-06
PCA Assembly Number                  : 800-27630-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC13450K2E
Top Assembly Part Number             : 800-29039-03
Top Assembly Serial Number           : FTX1347912G
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1252AG-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:06.243: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:07.071: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:07.567: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:07.591: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 12 messages)
*Mar  1 00:00:08.539: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:09.527: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:09.527: %SNMP-5-COLDSTART: SNMP agent on host APc47d.4f39.3ffe is undergoing a cold start
*Jan 20 18:19:18.035: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 20 18:19:18.195: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Jan 20 18:19:18.195: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 20 18:19:18.195: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan 20 18:19:18.199: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Jan 20 18:19:18.503: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jan 20 18:19:18.503: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 20 18:19:19.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jan 20 18:19:19.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Jan 20 18:19:26.911: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 10.1.50.169, mask 255.255.254.0, hostname APc47d.4f39.3ffe
*Jan 20 18:19:36.855: Logging LWAPP message to 255.255.255.255.
*Jan 20 18:19:39.551: %CDP_PD-4-POWER_OK: 16.8 W power - NEGOTIATED inline power source
*Jan 20 18:19:39.567: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan 20 18:19:39.583: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 20 18:19:40.555: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Jan 20 18:19:40.555: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Jan 20 18:19:40.567: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (192.168.10.207) (192.168.10.204)
Translating "CISCO-LWAPP-CONTROLLER"...domain server (192.168.10.207) (192.168.10.204)
*Jan 20 18:19:47.075: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Jan 20 18:19:47.075: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Jan 20 18:19:47.075: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Jan 20 18:19:59.091: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Aug  9 15:44:11.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.50.21 peer_port: 5246
*Aug  9 15:44:11.999: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Aug  9 15:44:12.639: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.50.21 peer_port: 5246
*Aug  9 15:44:12.639: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.50.21
*Aug  9 15:44:12.639: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Aug  9 15:44:12.743: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Aug  9 15:44:12.743: %CAPWAP-3-ERRORLOG: Starting config timer
*Aug  9 15:44:12.843: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Aug  9 15:44:12.847: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Aug  9 15:44:12.851: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Aug  9 15:44:12.855: %CAPWAP-3-ERRORLOG: CAPWAP moved to Run stopping config timer
*Aug  9 15:44:12.855: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller hornell-wlc2
*Aug  9 15:44:12.899: %LWAPP-3-CLIENTEVENTLOG: SSID HB_Corporate_Internal added to the slot[0]
*Aug  9 15:44:12.899: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
Surendra
Surendra BG
Right but it needs to join the primary controlller and not the standby.  Do you know of a setting that will force it to the primay?
Primary Controller
controler name
10.1.x.x
Secondary Controller controller name10.1.x.x
Tertiary Controller
Surendra
Surendra BG
