How do I block access to my wireless controller 2504 by MAC address?
KYLE NGUYEN
If i know the MAC address for certain devices, how can I block them from connecting to my wireless controller?
Cisco wireless controller 2504.
Thanks.
Rasika Nayanajith
You can add clients MAC address that you want to disable
Security -> AAA -> disabled client
This will effectively block these MAC address connecting to your wireless network. Does this achieve what you want ?
Rasika
*** Pls rate all useful responses ***
5 Replies 5
Rasika Nayanajith
Rasika
Yes, it works perfectly. It still prompts for the password, but will not connect even with the correct password. thanks.
@Rasika Nayanajith wrote:
Rasika
Sorry in advance, I'm new to this kind of things. Where do I can find that "AAA"?
If you only have access through the wireless controller via CLI, how would I block mac addresses?
From the CLI use:
config exclusionlist add 00:00:00:00:00:00 "reason for adding"
To see the MACs you are denying look at:
show exclusionlist
