How do I check to verify that APs are broadcasting SSIDs? 9800 WLC
JWHolm81891
I have a location that has been working well for several months to maybe over a year now that all of a sudden has an issue where clients can't authenticate or can't connect. They are getting on their phones a “couldn’t authenticate connection” error, and the iPad used for a room just says “couldn’t connect to network”. Every once in a while if they attempt to connect 5 or 6 times in a row it will randomly work and stay connected for a few hours, but there hasn’t seemed to be any kind of pattern to it. Looking in the 9800 controller, everything is good, switches are good. I'm a little lost as to what it could be all of sudden. No config changes have been made. They were configured in flex mode. How do I go about checking if the APs are receiving the config and are broadcasting the SSIDs correctly?
Leo Laohoo
  1. What is the firmware of the 9800?
  2. What authentication method, PSK or RADIUS?
  3. What does the log say?
marce1000
 - Is the baseline wireless environment still 'green' meaning , are for instance interferers growing and or disturbing your wireless network ? Also review the 9800  configuration with the CLI command : show  tech wireless , have the output analyzed by  https://cway.cisco.com/tools/WirelessAnalyzer/  , please note do not use classical show tech-support (short version) , use the command denoted in green for Wireless Analyzer. You can also perform client debugging  : https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213949-wireless-debugging-and-log-collection-on.html  , you can have these analyzed with : https://cway.cisco.com/tools/WirelessDebugAnalyzer/
 M.
ammahend
There is no wrong way to start, you can first start by looking at AP and making sure AP has all 3 tags assigned and none of the tags are default, it will mean whatever you configured on wlc is pushed to the AP, then  you can run a radioactive trace for any 1 client MAC address with issues, then if possible do a wireless capture at site and share here. Wireless connection goes through several stages before connecting, we need to understand at what stage it’s failing first.
-hope this helps-
