How do I increase web-based GUI timeout? Aironet 1142, IOS 12.4
DavidMach
The GUI times out after 60 seconds.
Since the the "exec-timeout" setting has a default of 10 minutes (if I'm not mistaken), I don't think I could change the timeout value with that command.
Under the "Association" tab of the GUI, there is an "Activity Timeout" subtab and settings for 5 device classes, all set at 60 seconds.
I would guess the setting in question can be configured here.
Is the client station device class what I'm after?
Erwin Salazar
To configure the parameters for closing connections to the local HTTP
server, use the ip http timeout-policy command in global configuration mode.
To return the parameters to their defaults, use the no form of this command.
The complete command is:
Syntax Description
Idle seconds:
The maximum number of seconds the connection will be kept open if no data is
received or response data cannot be sent out on the connection.
The valid range is from 1 to 600 seconds (10 minutes).
The default value is 180 seconds (3 minutes).
Life seconds:
The maximum number of seconds the connection will be kept open, from the
time the connection is established.
The valid range is from 1 to 86400 seconds (24 hours).
Requests value:
The maximum limit on the number of requests processed on a persistent
connection before it is closed.
The valid range is from 1 to 86400.
The default value is 1.
Defaults
HTTP server connection idle time: 180 seconds (3 minutes)
HTTP server connection life time: 180 seconds (3 minutes)
HTTP server connection maximum requests: 1
Reference:
http://www.cisco.com/en/US/docs/ios/12_3/configfun/command/reference/cfr_1g04.html#wp10296
12
Cheers, Erwin ______________________________________ How helpful was I? Don't forget to rate me when you have the chance!
