06-06-2015 02:36 PM - edited 07-05-2021 03:21 AM
I received a Linksys by Cisco Wireless Router from a client that no longer needed it. It's a model WRT320N.
I am a novice and need some help doing a reset if the device so I can use it.
He hasn't used it in a while and doesn't know the password.
I can see the User ID but that's it.
Any help would be extremely appreciated.
I'm using Windows XP
06-07-2015 09:13 PM
06-11-2015 08:10 AM
Use the Reset Button at the back panel of your device.
Once reset, follow the following steps to access the Web-Based Utility.
