how i can create multi SSID with separate VLAN in CTVM ?
Murad*
 HI
I have CTVM , and i read some paper that guide me to active flexconnet at AP , and i create management vlan with internet service , and every thing working normally , but when i create new SSID on new interface , and i connected on this new SSID the device had IP from the old management vlan !!
who i can separate the the SSID management and service if i want to broadcast different SSID in the same time on the same AP ??
pieterh
the setup will be similar to a physical controller
in the virtual controller you need to create multiple dynamic interfaces with a vlan tag and ip-adddress and use this for the WLAN
in you VMware host you need to modify your network to accept multiple vlans from the virtual controller and pass those vlans to your network
depending on internal or external dhcp server you may need to configure your dhcp scopes and dhcp proxy or relay accordingly.
