How long are login credentials cached for?
srosenthal
Level 4
Level 4
Our wireless setup is LWAPP with 4404 authenticating to an ACS using 802.1x. After connecting the wireless network and providing a username and password, how long is that information cached?
For example, I noticed if you turn off the laptop and then turn it on again, it automatically connects to the wireless. Is there a way to force re-logon after a certain amount of time?
Seth
paulpoon
You can use session timeouts on the WLC, under WLAN, advanced.
Session Timeout (secs) - Set the maximum time for a client session before requiring reauthorization. Default = 1800 seconds.
zhenningx
Level 4
Level 4
Cached credential is how Windows works with PEAP:
http://support.microsoft.com/kb/823731.
Zhenning
