How many AP supported in each branch office-Flex7500
raymond wang
From the document, it said only 50 AP supported in each branch for 7500. My case is the HQ has about 100 AP and other BO has less than 10 for each. I am planning to deploy 7500 in the DC and all the AP are in flexconnect mode. But since the limitation of the AP number for each branch office, I can not deploy 7500 in DC to manage the HQ office AP at all. Any idea?
<A href="http://www.cisco.com/en/US/products/ps11635/products_tech_note09186a0080b7f141.shtml#wbnd" mcehref="http://www.cisco.com/en/US/products/ps11635/products_tech_note09186a0080b7f141.shtml#wbnd">http://www.cisco.com/en/US/products/ps11635/products_tech_note09186a0080b7f141.shtml#wbnd
Data
640 kbps
300 ms
50
1000
Data + Voice
1.44 Mbps
100 ms
50
1000
<BR type="_moz" mozdirty></P>
Scott Fella
That is for FlexConnect groups. You can have as many FlexConnect APs as you want. You would just have to use multiple FlexConnect Groups if you require using FlexConnect Groups. This is really only used if your using 802.1x and have multiple radius servers.
-Scott
Thanks Scott. I do not need to create the flexconnect group in my case since all the authenication will be on the ACS+AD. Does that means 7500 meet my requirement-HQ has 100 AP and branch office has less 10 AP, ACS+AD in HQ, 7500 in DC, 5508 in DC as ancher.
Thanks!
You will be fine then.  I have some installs with 150+ FlexConnect at a given location and some as small as 1 FlexConnect AP.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
