How many APs Can I join a WLC 4402 and WiSM?
danielnunes
I have a WLC with 20 APs joined into the same management VLAN and
I'll deploy other campus with 240 APs and 2 WiSMs Blade.
Is there any recomendation about how many APs Can I put on the same management VLAN?
thanks a lot
Leo Laohoo
WiSM can support up to 300 APs (150 APs per "side").
WLC44002 can support EITHER 12, 25, 50 and WLC4404 can support up to 100.
WLC5508 can support from 12, 25, 50, 150 and 250 base on the license purchased.
Ok, but Can I put all LAPs on the same Vlan? or Do I need to separate my 250 LAPs on many AP-management vlans?
I wondering about broadcast storm with many LAPs on the same VLAN management.
Cisco recommends 60 - 100 access points per vlan. Attached is the best pratices document
https://cisco.hosted.jivesoftware.com/docs/DOC-4204
