how many clients does the 3800p AP supports?
pavel.mr4
Hi everybody,
Does any body knows how many clients does the "p" series of the 3700 / 3800 AP can support without service degradation?
an aproximate or an avergae?
Regards!
Rasika Nayanajith
You can check those AP features using below link
http://www.cisco.com/c/dam/assets/prod/wireless/cisco-wireless-products-comparison-tool/index.html#/wireless
Though theoratically each AP radio can support 200 clients, you should not design your wireless network to have that many clients.
In typical enterprise environment I would use 20-30 client number per radio
Rasika
*** Pls rate all useful responses ***
Thanks Rasika,
I understand the 3800p is for hd enviroments isn't it? But I can't see significant diferences between 3800p and 3800i/e, besides of the antennas.
Regards!
