How many clients support Cisco AIR-AP1242AG-A-K9
Ivan Jovovic
Dear all,
I have question for you how many clients have recommended be hooked on Cisco AIR-AP1242AG-A-K9
simultaneously.
Ivan
Leo Laohoo
It's got nothing to do with the model of the WAP of your choice.  The main question is what kind of traffic are you going to have.
The traditional Cisco rule-of-thumb is 25 clients per WAP.
However, if you are pushing, say, emails, web browsing, IM's and FB-like traffic then this number may as well go up to 35 clients per WAP.
But if you are going to start pushing HD video then the number is 8 clients per WAP.
Another thing to also consider, if you want to push high bandwidth applications, like HD video for instance, please take note that the 1242 only has 802.11 a/b/g radio and does NOT support 802.11 n and/or ac.  This model also has a FastEthernet port.
Thank you very much.
