How many simultaneous SSID ?
ROBERTO TACCON
Level 8
Level 8
How many simultaneous SSID can I configure on Cisco AIR-BR1310G ?
Thanks in advance.
Rob Huffman
Hi Roberto,
You can configure up to 16 SSIDs on your access point/bridge and assign different configuration settings to each SSID. All the SSIDs are active at the same time; that is, client devices can associate to the access point/bridge using any of the SSIDs. These are the settings you can assign to each SSID:
•VLAN
•Client authentication method
Note For detailed information on client authentication types, see "Configuring Authentication Types."
•Maximum number of client associations using the SSID
•RADIUS accounting for traffic using the SSID
•Guest mode
•Repeater mode, including authentication username and password
•Redirection of packets received from client devices
http://www.cisco.com/en/US/docs/wireless/access_point/1300/12.3_4_JA/configuration/guide/o13ssid.html#wp1002608
Hope this helps!
Rob
mrbelcher
Visitor
Not sure about the BR1310G, however I believe that the limit is 8 SSID's per AP. I have personally done 4 on a 1131G, but am not sure about the 1310G.
Rob Huffman
Hi Roberto,
•VLAN
•Guest mode
Hope this helps!
Rob
