How to access Web GUI Cisco C9120AXE-E with WLC
AMJAD BADAR
To all cisco gurus,
I am first time Cisco user and struggling configuring the Cisco AP.
I have connected the Cisco AP with PoE Switch. The AP is in operational state LED Alternating between Green and Red as per user manual
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/9120ax/quick/guide/ap9120ax-getstart.html#pgfId-69227
The device gets the IP address from the PoE switch which is also configured as DHCP server.
Cisco AP (192.168.127.1) <------PoE--------> Switch <-------- LAN---------> PC (192.168.127.2)
PC can ping to AP [OK]
Access AP web GUI does not working either http and https://192.168.127.1
any help would be highly appreciable.
Thank you for your help in advance
5 Replies 5
Mark Elsen
  - @AMJAD BADAR    The access point is in client mode (CAPWAP) and then it can only attach and or join a controller which handles it's operations (there will be no GUI in this case).
                                   You can convert the access point to standalone called embedded wireless controller (EWC) in this case ,checkout : https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html
        (if desired)
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
AMJAD BADAR
@Mark Elsen  Thank you for your speed of light response.
I got my infrastructure ready and now trying to upgrade firmware as stated in the link you provided.
I got following error incomplete command ? any idea why ?
AMJAD BADAR
I used the command with both files, command works but go another issue. Seems ap1g7 is failed. I have attached logs
ap-type ewc-ap tftp://192.168.127.220/ap1g7 tftp://192.168.127.220/C9800-AP-iosxe-wlc.bin
AMJAD BADAR
Ok I ran the commands again and download successful.
