How to activate Cyclic Shift Diversity (CSD) on a controller
Francois Verges
Hi everyone,
I am working in an environment where I could use the benefits of Cyclic Shift Diversity (CSD).
I know the AP 2602 I am using is compatible with it according to the data sheet. However I don't know how to check if it is activated or not on the controller (5508 v7.6.130).
I configure the controller directly on the GUI interface and I didn't find anything about CSD in the Help guide nor in the WLC Config Guide.
Thank you very much.
François
Saurav Lodh
Level 7
Level 7
It is enabled (default),
You can change it to single mode and see the changes in OFDM
config 802.11a antenna diversity sideA <CiscoAP>
verify by doing a "show controller dot11radio1"
Transmit Antennas : right-a left-b, ofdm single
Saurav Lodh
Level 7
Level 7
Thank you Saurav.
Your help is much appreciated :)
François
