How to add an SSID to AP's through WCS 4400?
jonesm111
We have a new SSID that needs to be added to an AP through a 4400 Controller with software version
7.0.116.0
All AP's are configured as Lightweight.
Can anyone assist?
Thanks!
---Mike
George Stefanick
You can add the WLAN via the Wlc under the WLANS tab or you can push the WLAN in WCS if you create a template. How many controllers do you have and do you have WCS ?
George Stefanick
We have 2 controllers and I believe we have WCS but not certain how to verify
If I connect to the controller that manages the AP I want to connect, Go to the Wlans tab, I see the following optiions:
1. Wlan Configuration
2. AP Groups
Not sure what to do from there...
Thanks George,
That was enough info to figure it out..
I then went to AP Groups --> Add Wlan Profiles and found the profile I needed
--Mike
Excellent .. Stop back if you have any more questions.
__________________________________________________________________________________________
