How to block same vlan communication in wifi
Debabrata Majhi
Can any one help me to protect host to host communication in same vlan(SSID).Like we can block host to host communication in Cisco 2960 switch in interface command "switchport protected"
Rasika Nayanajith
If you have a single WLC, then you can use "P2P Block Action" on WLAN -> Advanced setting page as shown below.
If you have multiple WLCs & you want to do that, then you have to use your switch to do that. In that case you configure that feature with "forward-upstream" option.
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
Hi Rasika Nayanajith
Thanks for awesome  support.
