How to broadcast both 5.0 Ghz and 2.4 Ghz?
alexmschade
I have a computer science background but not much knowledge of computer networks and installation. I just installed a cisco 3602i router connected to a 2500 wireless controller. Everything is working fine, the SSID is broadcasting and users can connect to the network. My question is this: in order to use both 2.4 and 5 Ghz band radios, do I need to create a new and separate SSID? I honestly cannot find online how to even select 5.0 vs 2.4 in the web GUI or CLI. Am I just completely missing something or are the frequencies just automatically chosen when connected to the network>?
Leo Laohoo
If you go to WLAN > SSID and look under Radio Policy, it will tell you which radio the SSID will be broadcasted.  If you chose "All" then the SSID will be broadcasted on both radios.
Leo Laohoo
