How to Capture Wireless Sessions
LibraryGirl
Community Member
Hi!
I'm new here, and I work for a public library. Maybe you gathered that by my name! I need to report how many wireless sessions happened in our libraries for the past fiscal year. Does anybody know how to do this?
Thank you!
ww^
Meraki Community All-Star
org》 summary report
or
org 》 Location analytics select range and download CSV .
6 Replies 6
ww^
org》 summary report
or
LibraryGirl
Community Member
Thank you!
I used the second option. I like that you're given the option to differentiate between visitors and passerby.
jdsilva
Level 11
Level 11
And here I thought you just really liked books... 😉
You won't be able to do this for the last year... But if you use the Summary Reports page under Organization > Summary Reports you can pull 6 month intervals and add them together.
I'm not sure if this will do... But it might be as close as you can get. The other option would be to call Meraki support and ask them to pull that data for your fiscal year (I don't know if they can... But worth asking).
Thank you! I DO love books, that's true 🙂
jim2
Community Member
We are a library network and I advise our libraries to run a summary report on the public hotspot SSID monthly and have it emailed. They then just plug it into a spreadsheet for their annual ARIS report. We use a splash page to protect the library from liability for copyrighted materials being downloaded on the public wireless device. In the summary report the accurate number would be the devices granted access by actually accepting the splash page. The number of devices otherwise could be just devices connecting but not actually accepting the page and using the internet.
Hope this helps!
Anne
CW MARS
bark.cwmars.org
Anne Savoie
NTBaugh
Community Member
This report no longer provides "Number of sessions over time." Is there another solution to getting number of sessions?
