how to change MNC& MCC in 3G-CDMA please help
I have a Cisco  HWIC-3G-CDMA-S card I activate it and everything is good but my service provider asked me to change the MNC and MCC (Mobile Network Code and Mobile Country Code) but I found no command that can do it because it is CDMA and has no SIM so I would be grateful if you help me with the command that can change those parameters .by the way there is command to change them in GSM cards so Are there any command which  can do the same with CDMA .I have searched in every pdf in Cisco site but I found nothing.
I appreciate your help
0 Replies 0
