I found out what the problem was.
In the WEB interface of WRV200 there is an error. If I set Wireless Isolation (within SSID): disabled then the isolation is enabled, so the computers can not see each other within the same SSID. If I set it enabled then it is disabled, so the computers can see each other.
Maybe a fix would be great for this.
Attila Mesterhazy
