How to check for heavy wireless users in WLC?
Marc Abaya
Is there a way to see who is consuming the bandwidth most using the GUI or CLI in Wireless Controller, without enabling Netflow? Either finding the IP add or MAC add will work.
On a switch, I can easily do this by using "show interface summary" and it can tell which port is the busiest and then get the MAC add associated for that port. Is there a similar command for WLC?
5 Replies 5
Rasika Nayanajith
What model of WLC and what software version you run ?
In 8.1.x onward I think you have nice dashboard, so you can see top users in a dashlet, but I do not think you can filter it by time base and identify a top user in particular time period though. Here is an example of my WLC running on 8.1.x code.
Netflow is the best for those sort of use.
Rasika
*** Pls rate all useful responses ***
Thanks for the reply. Ours is a 2504 WLC  and older FW 7.6. It doesn't have that feature yet.
Any CLI commands that I can use as a work-around?
In our version, I can open all the connected clients but it doesn't say the usage on the columns. Although I'm curious on how they sort the users on this? Is it by volume?
No.  Upgrade to the latest 8.1.X and this feature is available.
alberx
Hi Robert,
you can configure AVC (Application visibility) in WLC, follow this link:
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/115756-avc-guide-00.html
After configured you can see by WLAN, application or client the consuming bandwith. Also if you prefer you can check by CLI:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-5/command/reference/cr75/cr75_chapter_010.html
For example:
(Cisco Controller) > show avc statistics client 00:0a:ab:15:00:01 application http
 Description                   Upstream      Downstream
  Number of Packtes(n secs)         5059            6369
  Number of Bytes(n secs)         170144         8655115
  Average Packet size(n secs)         33            1358
  Total Number of Packtes         131878          150169
  Total Number of Bytes          6054464       205239972
  DSCP Incoming packet                16               0
  DSCP Outgoing Packet                16               0
Thanks will take a look.
