Remote APs having difficulty creating DTLS connection
johnmay
Community Member
I have a client with a 2504 WLC with both local and remote access points.  The remote access points are 1040s across a 10Mb MPLS.  When rebooting the remote APs, it can take anywhere from 15 minutes to an hour or more to complete registration.  When looking at the logs on the AP, I see this:
*Feb 3 21:05:24.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to <WLC AP>:5246
*Feb 3 21:05:25.051: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Feb 3 21:05:25.052: bsnInitRcbSlot: slot 1 has NO radio
*Feb 3 21:05:25.074: %LWAPP-3-CLIENTERRORLOG: Config not right for slot 1, not initialising slot config for this slot
*Feb 3 21:05:25.104: Starting Ethernet promiscuous mode
*Feb 3 21:05:35.117: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb 3 21:06:38.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: <WLC AP> peer_port: 5246
*Feb 3 21:07:37.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to <WLC AP>:5246
*Feb 3 21:07:38.000: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb 3 21:07:08.000: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2208 Max retransmission count reached for Connection 0x1F9E7CC!
This repeats several times, until it finally connects, and the Send FATAL line is replaced with this:
*Feb  3 21:08:52.928: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: <WLC IP> peer_port: 5246
The interesting thing is the time period between the connection request and the failure is exactly .999 seconds, every time.
Could this be a latency issue, or is there a problem with the controller and AP firmware?  They are currently running 7.6.130.0, which I know is deferred, but the deferral notice didn't mention anything about this issue.
Thanks in advance for any help!
George Stefanick
Hi John,
Do you have the APs sam model working ? Is it just this MPLS link not working ? Are there other aps across this MPLS working ?
Sorry for the late reply on this!
MPLS seems to be working fine - I can ping across the link the entire time during registration, though the latency does sometimes jump into the 150-200ms range.  All of the remote APs exhibit the same behavior, and they are all the same model.
