How to check roaming status
K.Inaba-MD
I have a question regarding the following products.
 WLC:C9800
 AP:9164
Is there a command to check roaming status?
Stefan Mihajlov
@K.Inaba-MD
To check roaming status on a Catalyst 9800 WLC with APs like the 9164, use the following commands:
  1. show wireless client mac-address <client-mac> detail – Provides detailed client info, including roaming history and current AP.
  2. show wireless client eventlog mac <client-mac> – Displays event logs related to the client's roaming.
  3. show wireless stats client detail – Shows roaming statistics for all clients.
  4. show wireless stats mobility – Displays global roaming statistics (intra/inter-controller roaming).
  5. show ap name <AP-name> client summary – Lists clients connected to a specific AP to track roaming patterns.
Ensure 802.11r is enabled for seamless roaming, and mobility group configurations are correct.
If this post was helpful, please click Helpful. If it resolved your query, select Mark as Solution from the dropdown menu in the top-right corner of this reply.
Leo Laohoo
show wireless client mac <MAC ADDRESS> mobility history
Stefan Mihajlov
@K.Inaba-MD
What you meaning roaming state? Can you elaborate
MHM
K.Inaba-MD
Thank you everyone.
