how to configure Cisco AIR-AP1242AG-N-K9
ahnoman231
Hello everyone!
i have a Cisco AIR-AP1242AG-N-K9 accesspoint and i want to configure it.
i am fed up of checking all the help guides and trying different methods like,connecting via Ethernet to serial port to access it through web browser and also connected through console port to access it via putty.
but still i am unable to go through it,can any one help me to get out of this so that i can be able to configure the accesspoint?
6 Replies 6
Rasika Nayanajith
Pls share "show version" output from your AP. Also attach "show run" output as well.
Also what are your requirements ? Do you simply need a wireless SSID to be configured or anything else ?
Rasika
the thing is,i am unable to connect it through console or through web browser,can you please let me know the brief steps on how to connect it to PC?
Try to default the ap by holding the mode button down for 30 seconds and powering up the AP.  Release the mode button after 10 seconds and then you should be able to follow the guide mohanak provided
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-4_21a_JA1/configuration/guide/scg12421aJA1/scg12421aJA1-chap22-trouble.html#wp1058433
-Scott
-Scott
Please help  how to Factory reset this AP ?
1: After active user mode
button pressed for 22 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
ap:
ap: erase startup_config
Unknown cmd: erase
ap:
2: Show version but i forgot my password
APVNMP24>show version
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:44 by alnguyen
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
APVNMP24 uptime is 9 hours, 3 minutes
System image file is "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx"
cisco AIR-AP1242AG-E-K9 (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCW1247U0AW
PowerPCElvis CPU at 266Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:22:90:1C:AA:1E
Part Number : 73-10256-07
PCA Assembly Number : 800-26918-06
PCA Revision Number : A0
PCB Serial Number : FOC12433QLQ
Top Assembly Part Number : 800-29233-02
Top Assembly Serial Number : FCW1247U0AW
Top Revision Number : A0
Product/Model Number : AIR-AP1242AG-E-K9
Configuration register is 0xF
